Hello!
Left my Ryker at the dealer to do the first yearly service. Did it so there wouldnt be any issues in case something failed during the warranty period.
Drove it home from the dealer, a drive of about 40 miles. Later that day i drove another 80 miles. The day after i decided to check the oil level and when the engine was hot the level was way above max, as much above as the distance from min/max on the dipstick but above max.
Checked several times at working temps, letting it idle and so on.
When it was cold the level showed max.
I have sucked some oil out and the oil level is now fine but...
Do i need to worry that something might have taken some damage? Or is it more like the engine would have failed while it was overfilled and everything should be fine now? No leaks
