Amsoil Test Results
I have a friend with a Dodge 2500 with a Cummins diesel. He has about 250,000 on it now. Since it was new he has used Amsoil and had it tested. He routinely gets 25,0000 miles between changes! He also uses a high performance filter.
I use Amsoil in all my gasoline driven equipment except the Spyder. I got the maintenance agreement so currently I use their BRP oil. Once the agreement expires, I'll use Amsoil.
Love reading about good results like this.
However, I am not a follower or a sheep if you will. Therefor I must ask. Who is the Lab? Amsoil? Independent Lab? I am sceptical of any "In-house" test... That is not the same as not believing them mind you, just requires more testing and or salt with the info :thumbup:
Good point. As far as I know, Amsoil does not do any 'For Sale' in house testing. They use Oil Analyzers, Inc. which is marketed as a subsidiary of Amsoil, Inc. However, the laboratory physical addresses for Oil Analyzers, Inc. and Polaris Laboratories are the same, (Indianapolis, Houston, Salt Lake City, Edmonton), so they are also marketed as an independent company as well.
The lab is ISO accredited so they have to meet the strict testing/reporting guidelines required for that. They're not going to be able to fudge numbers and keep that ISO status. They test all kinds and brands of oil just like the other oil testing companies out there.
I think you can trust their analysis. It would be too easy to verify the results for them to want to mess with the data.
I also sent in a sample from another Spyder and it didn't come back so good.
Ron,
Thanks for the killer post.
Can you copy us a link to the oil you're using? I would like to stay full synth, and rather than suffer the public ridicule from Nancystoy any longer, I'm considering switching to Amsoil. :rolleyes:
No one should run a lubricant (or anything else) to keep from suffering 'Public Ridicule', even if it is from Scotty! But I think you're just kidding.
Instead of a link, you'll be better of purchasing from one of the sponsors that offer Amsoil here at Spyderlovers. You'll get it for less money that way.
There is only 1 Amsoil product that is suitable for the Spyder (but then you only need 1) It is the 10w-40 MCF Full, True Synthetic motorcycle oil.
images
Also, has anyone used the K&N oil filters, especially since the change to the OEM filter?
Thank you --Pete
HiFlo makes the K&N oil filters. Same filter with red died paper and a higher price (Great marketing angle, customer pays more and is happy about it!).
HiFlo (and therefore K&N) do not yet carry the longer Transmission oil filters. I've been working with HiFlo toward that end. I hope to have them soon but I have not been given a date.
Automobile oils and motorcycle oils are not the same
Thought you folks may be interested in this article.
Article by Dan Peterson Vice President of Technical Development at AMSOIL
One of the sure signs of summer is the abundance of motorcycles operating on the roads of North America. And it seems like that there are more motorcycles than ever on the highways and byways, thats because, there are in 2012, nearly 9.5 million motorcycles where registered in the U.S. alone. That figure has grown by more than 47% since 2002, when the total was slightly more than 5 million. Motorcycle culture and the thrill of the pen road bring thousands of new riders and enthusiasts into the hobby every year. Although many “gear heads” love working on their bikes, few want to be doing repairs or experiencing down time from riding that could be prevented by basic maintenance. As with any vehicle powered by an internal combustion engine, proper lubrication is essential to ensure performance and longevity.
In the past, it was common for motorcycles to run on engine oils designed for four-stroke automobile engines. And if you spend anytime on online motorcycle forums, you’ll see plenty of folks still advocating the use of automotive oil for motorcycles. What is their rationale? there looking to save a couple of bucks on a quart of oil, as the majority oils blended specifically for motorcycle applications are more expensive per quart than their automotive counterparts. But is using auto oil in your motorcycle a good practice?
There are several reasons why motorcycle oils are better for your bike than automotive oils.
Motorcycles have fundamentally different lubrication requirements than automobiles. This is due primarily to differences in both engine design and vehicle applications. Motorcycles often operate under more severe conditions than passenger cars. They usually run faster, are air-cooled and share an oil sump between the engine, clutches and gears. The oil, therefore, must lubricate not only the engine, but the transmission and, in the case of wet clutch motorcycles, the clutches too. Many automotive oils, because of fuel economy requirements, are now formulated with friction modifiers. In a motorcycle with a wet clutch, these additives cause clutch slip and power loss.
Operating habits are different too. While many of us rely on a car or truck for year-round day-to-day transportation and for longer road trips, motorcycles are often ridden seasonally, on weekends or on shorter trips. These trips often occur during warm summer weather, when the cooling system has to work even harder. Thus,a motorcycle lubricant must protect against hi temperature and high engine rpm while providing smooth wet-clutch operation and protecting gears and chains from operational pressure extremes. Because of these factors, many motorcycle oils are engineered with high viscosity to help prevent gear pitting, oil burn-off and oil consumption.
Retaining that viscosity is critical to ensure components remain protected. The hi rpm and shared oil sumps common to motorcycles create an environment, in fact, transmission sets are the leading cause of shear-induced viscosity loss in motorcycle applications. The oil’s shear-stability and viscosity retention are vital for protecting motorcycles.
Additionally, motorcycles are often stored for several months during winter, a time when condensation can cause rust, which accelerates wear and can damage engine components. Rust is also a problem inherent to the shorter drive times motorcycles often endure. If not combated, rust can cause bearing corrosion which results in vibration, noise, increased temperatures and catastrophic failure. Effective motorcycle oils must include rust inhibitors to keep engines and components free from corrosion.
Motorcycle oils must also prevent foam from forming, which happens when air enters the lubricating oil during normal engine and transmission operation. Foam bubbles entering a lubricated area take the place of the lubricant film and compress easily, leading to metal-to-metal contact. Foam also promotes increased oxidation because more or the oil’s surface area is exposed to oxygen. An oil’s tendency to foam should be considered when selecting an oil for your motorcycle.
For many riders, motorcycles represent significant investments of thousands of dollars. It only makes sense to protect those investments with products tailored to address their specific lubrication requirements.
I ran standard dino oil for the first 1500 miles, and two oil changes, then switched to Mobile 1 V-twin full synth. The Spyder runs well, but eats a quart every 1,000 miles….
...then switched to Mobile 1 V-twin full synth.
Do you have a reason for running V-Twin? That's 20W-50. The BRP stuff and the manual recommendations are 5W-40. Amsoil is available in 10W-40. Mobil 1 Racing 4T is also 10W-40.
Also note that both Mobil 1 oils meet the JASO MA spec for good wet clutch performance. However, Amsoil meets the tougher JASO MA2 spec for even better wet clutch performance. If you find your clutch slipping at all with the Mobil, you might want to try an oil that meets JASO MA2. There are others besides Amsoil if you're not an Amsoil fan.
Some feel that thicker oil is better. 20w-50 will actually not work as well in the Spyder as the lighter 10w-40 (or 5w-40) oil. Your Spyder will run hotter with 20w-50 and will usually burn more oil too. Sounds counterintuitive, I know. But your oil ring has more trouble squeegee-ing off the thicker oil in a high RPM engine. More oil stays on the cylinder above the piston and it gets burned away. Tends to carbon up your cylinder as well. There are some great articles out there regarding this.
What you really want is the thinnest oil you can get that still does the job, taking into consideration that all oils will lose viscosity and lubrication effectivness with useage. Better oils maintain their viscosity and effectivness longer than lesser oils. Thinner oil actually lubricates better (as long as it isn't TOO thin), cools better, circulates better, etc.
Although BRP originally recommended their synthetic 5w-40 for the Spyder. They now recommend their blended oil which is 10w-40 (though it does not give any viscosity information on the container).
Ron, what were the numbers for the Viscosity (@100c) and for the Base Number?
They don't give you viscosity, they give you the Viscosity Index Number. I'm sure you know that is because viscosity has a spread so one 40 weight oil isn't necessarily going to be the same weight as another 40 weight oil. It's not really as confusing as it may sound.
Think of it as 40 weight, 41 weight, 42 weight through to 50 weight. They don't want to mess with breaking it down that far so any weight oil that is at least 40 and less than 50 is considered 40 weight.
Do you ever notice that true, Group IV base synthetic oils like Amsoil seem to be thinner than the same weighted dyno or sudo-synthetic oil when you poor it out of the can/bottle/whatever? Well, that is because true full synthetic oils don't break down like the other oils do so they can run closer to the actual spec. The manufacturer of a lesser oil knows that their product is going to break down faster. So they need to run it closer to the thicker end of the scale to start so that it doesn't fall below the minimum during use.
But for testing, you DO want to break things down into finer increments. So they use the Viscosity Index Number instead of the broad 'Viscosity Weight' numbers. So for this oil analysis, you want to compare the original Viscosity Index Number with the tested oil's number. This is a much more accurate way of knowing how much the oil degraded during use.
40 weight oil VIN goes from 12.5 (thinner) to 16.3 (thicker). So as you can see, if the report gave just the viscosity weight it would say 40. But what does that really tell you except that your oil is still within original spec. It won't tell you how much degredation occurred or how close to being out of spec the used oil is.
The original VIN for this oil is 13.8. My test result was 13.3. So I lost .5 VIN in 6,400 miles. The goal here is to stay at or above 12.5 so my reading is very good.
The original Base Number for this oil is 11.1. My test result was 7.40. The goal here is to stay at or above 50% of the original value (which would be just over 5.5) so again, good to go.
Thanks Ron, I have talked to you a couple of times, and you have sold me, on my next change, hope to see ya at SPYDERFEST 3.
You just can't beat Spyderfest and I do plan to be there. But aren't we going for #4?
Thank you for your response. That helps me feel very good about the testing actually. I used to send samples before buying vehicles, or for our plane. Spendy, but worth knowing just what is going on as we cannot really tell by just the coloring of the oil... :doorag:
No, you can't tell by color or even how it pours unless it's REALLY BAD.
One dissappointment I had in this test was that no particulate reading was given. After looking into this I believe that is an additional test proceedure which costs more money. I want to do this next time as it will tell me how well my filter is working.
I had a bit more fuel contamination than I'd like. It was in the 'Normal' range but at the upper end. I'm running a JB and I may have it set a bit too rich.
http://www.bobistheoilguy.com/viscosity-charts/
Ron, thanks for the info on the Viscosity index. For those of you who like to get some idea of what the oil has sheared down to, you can use the above chart. Your VI of 13+ is outstanding, showing the oil was still in the lower end of 40W or high upper 30W.
I've just sent off a sample of Valvoline 10-40 motorcycle oil, rated MA2, with 3000 miles on it to see how it fares. I'm using prepaid Wix sample containers that you can find by searching the internet. They use a lab called ALS Tribology. Search a lot as prices of these prepaid sample containers vary a lot. I found some for about $8 each.
I have not done a lot of testing so I am not sure. But I'm wondering if price has something to do with the quality and amount of information performed in the testing. $8 is definitly very cheap even if you add in shipping costs.
I agree that 10W-40 (or 5W-40) is the oil of choice for our Rotax engines. I was merely trying to find out why someone felt the need to switch to 20W-50. For curiosity's sake.
Not quite correct. The Viscosity Index Number is a measurement of how well the viscosity is stable over a temperature range. To quote: "The viscosity index (V.I.) of an oil is a number that indicates the effect of temperature changes on the viscosity of the oil. A low V.I.
signifies a relatively large change of viscosity with changes of temperature.
In other words, the oil becomes extremely thin at high temperatures and extremely thick
at low temperatures. On the other hand, a high V.I. signifies relatively little change in
viscosity over a wide temperature range."
The numbers you are quoting (12.5, 13.3, 13.8, etc) are the actual laboratory-determined viscosities for the oil samples, the units of the number being centistokes (cSt). For the high-temperature viscosity (the "30" or the "40"), the viscosity is measured at 100C or 212F temperature. So on your oil they measured 13.3 cSt at 100C. That is the actual viscosity of your oil at that temperature. Now, where does that actual viscosity fit in the scheme of things? For a "40-weight" oil as defined by SAE and API, the viscosity at 100C must be between 12.6 and 16.3 cSt as you stated. Your oil is still within that range so it is still performing at 40-weight levels. Very good. FYI, I submitted an Amsoil 10W-40 sample after some miles that came back as 12.06 cSt, just below the minimum of the 40-weight range. Still pretty good in my opinion but technically it was now at the top end of the 30-weight range (9.3-12.5 cSt). As for where it started out, Amsoil states that their 10W-40 is typically 13.8 but that doesn't mean every batch leaves their plant with that number. Could be more or less. We should all thank Amsoil for being willing to publish their "typical" numbers. Try to find that out for other oils!
As for VIN, that's something different, as explained above. Now, pure synthetics like Amsoil and Mobil 1 are known to have a high viscosity index, that is they change less with temperature. Lesser-quality oils tend to thin out with temperature and therefore have a lower viscosity at higher temperatures in their native state so the manufacturers add viscosity index improvers to the mix to improve the VIN. With good synthetics, there are fewer, if any, viscosity index improvers added to the mix. Intuitively, the fewer additives the better. At least as far as I'm concerned.
The Base Number, or Total Base Number (TBN) is a measure of the additives in the oil that are preventing acid formation and nasty things like that. Again, the 11.1 is "typical" of Amsoil but may not reflect precisely an actual oil that you received. There's no doubt that your 7.40 is a very good reading, however. In the sample I referenced above, my TBN had gone down to 6.1, still very good. Again, I thank Amsoil for giving us an idea ("typical") of where we started out, 11.1 in this case.
Bottom line -- I, too, was very pleased with my Amsoil test results. My sample was run at a different lab than you used and one that is not associated in any way with Amsoil. But we both got good results and that's what counts!
Is everyone awake??
I've used the Wix several times and thier lab reports are similar to those of Blackstone, both in quality and content. Both are used in the auto world and seem to me about equal. Blackstone sends you free sample kits and you pay when you mail in a sample (last time I used them last year it was under $25 not counting shipping; Wix kits are prepaid and can be found from various vendors from (currently) $10 to $20. Heres one I just found for $10+
:http://www.amazon.com/dp/B0014BEMVW...e=asn&creative=395105&creativeASIN=B0014BEMVW
You might get flak from your mail clerk who might say you can't ship oil. It isn't true, but you can't convince them. when asked if its "liquid, fragile, hazardous, etc, etc" I say no. I've found it best to put the kit in a brown shipping envelope. Doesn't raise eyebrows like the small container does, and also is less likely to get lost. If this bit of subterfuge bothers you, send it UPS or Fedex.
You can purchase a kit here - http://www.amsoil.com/catalog.aspx?GroupID=683
Or you can order them through me for $31.00 per kit - delivered. It's usually about a $4.00 savings.
This is for the postage paid kit.
I like what you have done and I buy my oil and filters from you. i inted to continue to do so since you do all of the due diligence on your products. Having Amsoil check their own oil is a bit suspect. Better would be to have a disinterested third party do it. I intend to do that and I will share the results with you.
As an aside; big recreational boats have fairly large diesel engines carrying 8 GALLONS of oil per side. Changing and disposing of this much oil is expensive. I have a freind who sends a sample in every year and if the results are good, and they always are, he changes the filters and runs it another year. Oil in this application tends not to wear out but only get dirty. I know it is apples to oranges but I thought I would share a different perspective and apologize in advance if this somehow hijacks this thread.
