altimax rt 43 215/60/15
ssmcclub
altimax rt 43 215/60/15 Just purchase this tire for rear of my 2014 rss .if anyone is running with this tire what air pressure do you recommend to use ?:bowdown:
TIRE PRESSURE
I have the same size in a Michelin....and because it has much stiffer side-walls I run mine ( on an RT ) one up at 21lbs cold.....The pressure goes up a bit as it heats up.............Car tires should not be run at higher PSI because they were designed for a much heavier vehicle.................JMHO.....Mike :thumbup:
Ah ooooo
attachment.php
^^ Wot 'e says!! :thumbup:
The more the tire is bigger than the standard size, the greater the volume of air encompassed inside it, but the load on it hasn't changed.... so for a bigger tire (or a more robustly constructed tire designed to carry bigger loads in the first place) you generally need LESS air inside it to carry the same load. ;)
I am thinking of getting that tire for my F3S....
i am interested in feed back as well...
It looks like a great choice for an RT. Not so sure I would want one on my F3. The F3 is pretty traction challenged as it is and going to a narrower 600 treadwear rating tire is GOING to reduce available traction. But then again, you may be fine with that.
I am looking at going with a Yokohama again or a Toyo performance tire for the added traction. I am actually getting better life from the Kenda than I did on the 2013 editions but will not buy them. I do not buy 'made in china' tires. Period. Well as long as I can get something else.
Altimax RT43
I put this tyre on last year. Runs and rides great at 26psi. Nice bonus having an accurate speedo too. ;)
So what I am getting here is I should drop from 28 to 26psi for the altimax? For some reason being stiffer I would need to go the other way to 30psi. Thats why I read these forums, to make some sort of 'educated' decision.
Their is a "Thread going on the General Altimax RT 43 tire" the Thread is titled" Deanna and mike Thank you", Started by safecracker. Look @ What's New? tab.
Deanna
mounting this tire
Just for grins, I checked out this tire on Amazon to see the reviews there. I found only one. To wit:
"I bought this for the single back tire to a Can Am Spyder RT and it works very well. It was a little difficult to install due to the 1/2" narrower bead, but once on and aired up I am very pleased with it."
So, my question is what's necessary when mounting to overcome this reviewer's "difficulty?"
I have a local tire shop in town which doesn't seem to be particularly bothered when asked to mount a car tire on a "motorcycle" wheel, but it would be nice to prepare them for any difficulty they might encounter.
Thoughts?
