3Ryder
My air shock does not respond to changed settings using the electric switch on the dash. I can go from one bar to six bars and nothing changes. Pressure simply holds steady. However, I can make the compressor work by holding down that same switch. I can drive the pressure to well over 100 lbs (which is beyond the specified top bar pressure). And the only way to make it decrease is to release air through the valve. I've done these tests with the bike in neutral and parking brake off.
Does this sound like a switch problem, a sensor problem, etc.? Thoughts?
