I have one of the JT mounts just behind the windscreen (above the dash). Currently, I have my phone mounted there (on a long RAM arm) and will be mounting a GPS there shortly. Currently, I have one of Lamonsters USB cable extensions run to the handlebars from the OEM USB connection in the frunk. I want to continue to use the cable but relocate it. I'll also need to run the GPS power cable (looks to be much more significant than a "power cord") to the frunk for power.
I want it to look as close to OEM/factory as possible. i.e. it could have come from the factory that way even though it didn't. I know I can't quite achieve that w/o drilling holes (which I'm NOT willing to do). I've seen a GPS wiring bundle run into where the safety card normally resides. That's ok but I'd prefer something a bit more stealthy. JT himself said running power wires into one of the windscreen arm holes is do-able but I'm not sure if there's room for the end of the USB and the entire GPS cable.
What have you done? (with pics, please) If you haven't ran wiring this way, what could you suggest? If need be, I'll rip out (sorry, gently remove) the safety card and run the wires that way but that doesn't achieve the look I'm after and I think I'd have to dismantle parts of the dash.
