So, let's talk about P0562. The ECM, Cluster and DPS all monitor voltage and will individually trigger a P0562. You shouldn't be getting that unless something thinks that voltage is somewhere around 10 volts. The TCM also measures voltage and will set a low voltage fault, but it's a different code. You don't have that. So, because you have a DPS fault, it might indicate that it's just the DPS that is not happy. But first, just to cover all of the bases. The voltage tests are performed at 4000 engine RPM. The stator puts out a 3-phase AC output. Measuring at the 3-wire connector from the stator, you are supposed to get a minimum of 60 VAC each on pins 1-2, 2-3, and 1-3. At the battery, DC voltage should be 13-14 VDC.
If you have that, then we could focus on why the DPS might be the only thing that is unhappy. Of course, you will want to check the fuses for the DPS. Both the main power fuse in the fuse box under the seat - #5 -, as well as the DPS fuse in the front fuse box F3. But, good practice is to test them all, not just look at them.
If all is well, then historically, grounds have also been known to corrode. Your machine is fairly old. There's that main battery ground under the seat right next to that fuse box. Be careful working around that. There is a nut on the bottom side of that bolt. Almost impossible to get to from above unless you bend a wrench, Just pull off all the panels on the right side, remove it all, clean it all, and tighten it all.
Up front, on the left hand side, also awkward to get to, is another main distribution system ground. A lot of wire connections on that one. I believe the DPS ties into that one, but look around and see if there is also one for the DPS separately. Follow the harnesses. Again, remove all panels and such and you'll see it way down low in front, kind of on the left. Clean all of that up, too.
PS - Thought of a shortcut to some of this. There is that 12v accessory plug in your rear trunk powered from the fuse box. Measure voltage there and compare that to voltage directly at the battery. If it is low there, then it is low everywhere. Probably for a ground reason. If it is the same there, then most likely just your DPS is affected. Check DPS ground, check DPS supply from 40a fuse (#5) and at its harness connector, or possible failed DPS.
