Don't run it to empty!! :gaah: Well, not unless you really like damaging the injector system & starting down the path of some fairly expensive repairs anyway!! :lecturef_smilie:
Sure, you might get away with running it to empty once or maybe even a few times; but since the injector system, inc the injectors & the fuel pump, etc all use the 'remaining fuel' left in the tank as both lubricant and coolant for their important 'moving/operational' bits, running the tank to empty means that you
WILL be causing
some (altho admittedly, possibly microscopic) damage, and that damage is cumulative and irreversible!! :shocked: So just try your best to
NEVER run the tank to empty!! nojoke
All the GS/RS/RSS/ST's and the RT's up to and including the 2013's
do have a 6.6 gallon tank, but really only about 6 gallons at best is safely usable unless you want to kick off that previously mentioned damage; so from the factory, fuel gauge and the low fuel warning light are set to allow you plenty of time to re-fuel before things get too iffy.... but they are notoriously innaccurate and not really all that reliable!! I've had the low fuel light come on after
less than 18 miles from a very full re-fill; and at other times it hasn't come on until after I've been getting seriously concerned about using too much gas/getting too close to empty - and sometimes it's taken a smidge over 6 gallons to refill!! :sour:
So it's best
NOT to rely on the gas gauge &/or the low fuel warning light!! Use them as helpful indicators if you must, but you will be
MUCH better off to simply reset a trip meter every time you re-fill and progressively work out how far you can safely travel on your worst ever average mpg, then refill before that - you know, just like we all hadta do on just about every other bike we owned, back before they ever had fuel gauges!!
Oh, and the 2014 & on RT's & F3's all have a larger tank and a
slightly more accurate & reliable gas gauge.... but in my experience, the low fuel warning lights can still be juuust a little erratic in when they come on/how much is left in the tank; so it's probably
STILL a smart idea to reset that trip meter on them too!
:cheers:
