Accessory lights on 2016 F3 not working! Any suggestions?
sunflower
I hooked up Led strip light to the accessory cable in my frunk, started Spyder they did not work. The lights are good tested them. Any suggestions on what can be wrong, lights are from a Spyder dealer.
Double check your Neg-Ground connection or ON-OFF switch if you have it wired that way.
Check the voltage at the ends of any of the 3 customer accessory terminals.
The terminal in the frunk of my F3T is working and powers my insignia light.
Where is the 2017 F3T Customer Accessory Circuits fuse location
Looking at the battery from the front of the Spyder with the frunk liner out its the sixth Spade fuse from the top left in the left-hand fuse box.
Are all 3 Accessory circuits wired to the same fuse or fused independently?
All 3 Accessory circuits share the same fuse and only receive power with engine running so would be no good for a battery tender.
What is/are the total watts available for accessories?.
Fuse is 10 Amp so approx 120 watts.
