Accessories wires adjustment
You could also get the FZ fuse box and wire your stereo to the fuse box. This is what I use. Depending on where you put your fuse in, it will make that circuit hot all the time (you would use a switch on your accessory) or hot with key on and running.
attachment.php
Just want to pass on that I got the Stereo installed over the week-end I did the whole relay ordeal. Pretty nice.. I did hook up in the GPS plug and it all worked out perfect. Thanks for all the advice. Joe
