oldguyinTX
What is the best/easiest way to lubricate the frunk, seat, top case, & saddlebag cables? Would 3-in-1 oil work, or would another lubricant be a better choice?
WD-40 is not a lubricant .... It's only slippery when wet, after it dries it stops .... get a spray can of dry silicone .... it stays slippery for quite awhile ..... :thumbup:
WD stands for "Water Displacement", and 40 was the 40th chemical combination to produce the desired result.
Most modern cables have a silicon liner that the wire runs in. Manufacturers of these cables do not recommend any form of lubrication as it gives dust and dirt something to stick to.
Something similar to this if you can get to one end.
https://www.amazon.com/Motion-Pro-08-0182-Cable-Luber/dp/B0012TYX9W/ref=sr_1_55?crid=16QFNAZSUD6K2&keywords=brake+cable+grease&qid=1690306493&sprefix=brake+cable+grease%2Caps%2C103&sr=8-55
