2020 RTL Does it have a USB port in the frunk?
Escorial
I found the frunk light but no port, looked in the manual and saw nothing , I guess the answer would be no?
Just double checking.
TIA
You can add a USB port to the 2020+ RTL frunk if you'd like. By the battery there is a hole in the cover plate to add a cigarette lighter outlet. I read where there is a direct connection that can be used behind the opening but I just connected it to the battery. Once the plug is in you can use a USB adapter. I have an air pump that needed the outlet. Took about 15 minutes to install.
Too funny, as I asked about the frunk ( front trunk) as they call it on here..
The actual trunk is a no brainer.
I had the same thoughts, till I turned the bike on and opened the frunk.
May also work w ignition just switched on.
That is on 2020
