2020 RT pre-wired accessory (+12V) locations - are there three?
Is the auxiliary light in front plug & play?
The BRP one is plug and play - plug is already there for u to use - zip tied to cover plate.
I installed an aftermarket one ($24) and unfortunately had to cut factory connector off because I could not find a mating connector.
PM me if you choose to go aftermarket with a generic solution. Not recommended since factory is cleaner install. However light is super bright and has been working great.
