2018 RTL Brakes feel 'spongy' - Is this normal?
Rusty71
Newer owner, the 2018 has 13,000 miles, I’ve put about 1000 miles on the RTL so far. The brakes have felt “spongy” from my first ride, I’m paddle shifting to let the motor slow the trike at every stop. Is this normal? The brakes do squeal a bit till they warm up, then no noise. I think that may be a separate topic… thought I’d reach out to the forum before I go the service route. Your responses are appreciated.
Your brakes are not performing normally. It's your backside that's on the line here. I know a good bit about my roadster's brakes and sure wouldn't ride mine in the fashion you describe. Get thee to a service activity, PRONTO!!!
NOT NORMAL!
Get it looked at ASAP!
Definitely get it looked at.
Did you get any service records when you bought it?
Brake fluid is hygroscopic, which means it absorbs moisture from the air over time.
In the Maintenance Schedule section of my Operator's Guide it says the brake fluid should be changed every two years, regardless of the mileage.
