2016 RT Antena
michrick
My rubber grommet where the Antena goes through the trunk won' stay in :dontknow: is there a trick to keeping it in or how to do it. Thanks for any advice Michrick
Its not the best design in my book.
Line up the tabs and push in thats it.
After that try not touching it anymore or it keeps poping out
Or try contact adhesive if yoy want it to stay in place. :thumbup:
I just removed it and replaced with shorty antenna just to plug up the hole. It's pretty useless anyway, in my opinion.
make sure you have the taper/bevel the right way. It's designed to sit square to the angle of the tupperware. Other than that....it's just a silly design
First, make sure that your antenna is not loose.
Then put some silicone spray around the bottom of the boot so that it will slip into the hole all the way.
Push down and twist side to side slightly.......while lined up matching the slope of the body as mentioned above.
Thanks everyone for your comments. On this issue
Shorty antennas do they have a boot that covers
The hole up like the OEM boot
