John at Elka will set up F3 rear Elka with correct single 8" long spring for your weight.
But on F3, rear single spring needs to be stronger for driver only; and a even stronger single spring set up for 2 up riding to get correct ride height!!
A Rear F3 Elka dual shock springs John at Elka set up for a 250# rider was way too soft for ride height for rider; & 2 up riding!!
Should be a stronger 900# Hyperco single 8" long spring for 2 up riding.
Note: The dual springs on Elka rear shock do NOT work because they sag 2" when sitting on F3S with the Eibach 800# 5 1/4" long spring/800# 2 3/4" long springs.
(My rear Elka 650/800# dual springs was set up for 200# rider, (the 1 3/4" rear sag is way too much).
But I bought/installed Hyperco 800# single rear spring 8" long 2 1/4" ID, to get ride height up to normal 1/2" sag.
Hope this explains a little on F3 Elka rear shock spring sag problem.
Jim
After all that, it seems to me you should have just purchased a RT if you were looking to tour
Very nice DIY set-up :clap:..........Just throwing this thought out there.............back in 09, before the RT , I had a GS that I wanted more for touring than hot rodding.......So I put a 1200 Gold Wing windshield on it , and I mounted it to the HANDELBARS , the same way most ( if not all ) after-market windshields are mounted.......Considering the size of some of the F-3 handelbars, I'm surprised no one has gone this route and mounted that way........Mike :thumbup:
Thank you for the compliment but the credit goes to Spyderyderjim - a very creative and generous man. We have kept a continuous dialog via email for many months now - a true sharing and giving person.
What type---mfg of floorboard firm pad--source of purchase==where? Lots of rubber or foam padding but I'm concerned about wear--weathering appearance. Excellent idea to add padding to absorb vibration. I've also seen handle bar grip sleeve to absorb vibration.
Thanks for your post.:bowdown:
Darrell
Thanks everyone.
I just wanted to share what any DIY Guy/Gal can modify: F3S seat, backrest, add Givi storage equal to or maybe a little more than RT, Elka shocks, RT windshield with DIY 1/4" thick Aluminum flatbar/1" x 1" Angle brackets mounted, for a great F3S TOURING Spyder.
The stock F3 seat can be an easy mod with a Conformax 1" foam with attached 1/2" Gel facing down at seat base foam.
You just remove staples, pull off stock seat cover, cut out center stock foam, (leave edges of foam around seat base & about 1" stock foam over seat base), insert center cut out foam with the Comformax foam pad with Gel down; staple seat cover back on.
The 20" Conformax pad is enough for both Passenger & Drivers seat.
https://onlygel.com/index.php/confo...x-retach-anywheretm-gel-seat-cushion-265.html
Yes the seat is very comfy!!!
Enjoy.
Jim[/QUOTE
Hello Jim,
I was wondering on the BRP Floor boards you added 1/2' firm pad, did you add that on the top or bottom and how did you attach it.
Did you order a shorter Brake Linkage to lower the pedal and were from did you get it.
Did you get the Russell Backrest from Russell?
Any information would help
Thank you,
Kevkev
Givi Wingracks with Givi topcase mount; N141 (or N140 will work); with 15" long sidebar extension for topcase mount.
(special thanks to Guzzi for posting photos of his F3S Wingrack & sidebags)!!!
Givi E41NN sidecases.
Givi E52 topcase (will be replaced with new 2015 E56NN topcase later).
Thanks everyone.
Enjoy.
Jim[/QUOTE
Hello Jim,
Thank you,
Kevkev
Jim,
I am interested in putting Givi topcase and sidecases on my F3. In reading all the posts on what you have done it sounds like you had custom hardware made to get the cases attached. Would you be so kind as to list what hardware you were able to purchase and what needed to be fabricated? As well as any advise you are willing to pass on.
Thanks,
And by the way... your Ryde looks great!
