2014 with her coat off
bluestratos
FYI Here some pictures that show the new location of the air filter, horn and back of alternator. The air filter has a round cover that comes off in seconds to allow you to pull the round cartridge filter out. The horn easy to get at now and the middle picture is the location where I am install my after market water tight fuse panel. I will tap the + directly off of the alternator using a 50 amp fuse then through the relay that is controlled with a diode protected tap off of an accessory controlled wire.
Whoa!! :shocked: Nekkid Spyder!!
Where are the exhaust pipes in relation to the gas tank?
Each cylinder pipe exits on the front of the engine and go down to a tree to one pipe adapter. The three pipes have heat shields on them down to the adapter. Then the single pipe go toward the rear under the engine toward the catalytic converter, then the exhaust . Heat is well away from gas tank. So far no gas fumes as I experienced with my 2010 RTS.
