cognaccruiser
I have viewed Lamont's video for RS wheel removal and have searched for and found a number of threads but still have some questions.
For the RTS the removal of the Air Level Sensor Lever is required in addition. Does anyone have a picture of said lever? I would just like to know what it is that I'm looking for first. Maybe it is self evident once I lift the Spyder up but would like a better idea if possible.
Secondly, should the parking brake be disengaged at some point?
I saw some reference to removing clips from the caliper bolts when removing the brake caliper. Will this be obvious when removing the caliper?
The cotter pin on the 36mm nut will probably need to be replaced. Is there a specific size of cotter pin to use? Does anyone re-use the original cotter pin?
in Lamont's video he had to replace the O-ring on the hub assembly. Is this common or just a mistake in how it was removed. Is there a size that I need to know?
Does the axel need to be lubed before re-inserting? I saw something about coating it with anti-seize. Is that necessary?
Maybe I'm over thinking this but would like to be completely prepared. This is all in regard to replacing the rear tire which I want to do before spring and getting the Spyder back on the road before heading to Spyderfest. The trip we have planned will probably put on a good 5-6,000 miles.
Thanks in advance for any help.
Gary
Gary
