Gray Ghost
That's the key code isn't it? What switches?
Those numbers are the key code. However the security system on the Spyder is designed so that you can have a key cut to fit a byke, but if the transponder chip is not set up with the system using BUDS, the key will not start the byke. You would be able to open the luggage though.
