Had laser alignment done today. Took it in because it was pulling to the right pretty bad. When you slightly let go of the handlebars you can physically see the handbars move to the right causing the bike to turn toward the side of the road. This happens quick, not gradually. The laser alignment found the front end to be out 1 inch. This was corrected and the power steering set to zero via the computer. After alignment the bike still pulls to the right the same as before the alignment. The alignment did take care of other issues and bike goes down the road straight except for the constant pulling to the right. One service tech, service manager, and store manager took it for a ride and all agree it pulls, however, did not have an answer. We all then took the 2014 demonstrator for a ride and it pulls to the right the same as mine. Dealer is baffled and will contact BRP. They have only done one other 2014 laser alignment and had the same issue, however, corrected it by cheating the laser settings. At this time they do not want to cheat mine but want a true fix. Wondering if anyone else has had this issue. Only seems to be on the 2014. All of the other alignments they have done have been good.
