Welcome to posting on the Forum MBOZ, sorry that it's gotta be with a problem! Still, let' see if we can help! :helpsmilie:
The symptoms you're describing are almost invariably associated with poor battery terminal connections, dirty or loose ground connections, or an almost dead battery! This sort of thing isn't usually the Starter, but rather the load of
trying to start dragging the battery voltage down so low that the battery can't run the computers, the fuel pump, and all the electrics, let alone meeting the heavy voltage drain the starter puts on it! From the 'resets in about 10 mins' thing makes me think it's most likely going to be a dead or at least very tired battery, but that may well be that due to poor terminal or ground connections meaning it's never being charged properly, so you should check all those anyway!
If you can, get the battery properly load tested, altho you can do a quick & dirty check if you have & can use a multi meter. With the m-meter, check the battery voltage before you try to start it, when the battery is rested & theoretically good/at its best - if the charge is not above about 12.5 volts or so, you can
try giving it a good long battery charge with a smart charger to see if it recovers; but if it's anything below 12 volts it's probably a gonna ANYWAY & likely to need replacing. And if it's ABOVE that 12.5 volts, keep the multi meter on it while you try to start it - watch to see how low it drops, anything below about 10.6 volts means its properly cactus & there's little likelihood of recovery!!
Good Luck! :thumbup:
