Bike-O-Din
The last several (6 or 7) times that I have tried to start my 2011 RT-S, it starts rignt up, but goes immediately to the "Check Engine" mode. It runs terrible and even backfires occasionally. This is only for the initial start up from the garage/driveway. I shut it down, walk away with the key for a few minutes, and then return and it will start fine and then run all day, even with several stops and starts during the time I am out. Put it away for the night, and the same thing happens the next time I start it from completely cold.
I have plenty of power to run the starter, so it does not seem to be battery related. I have removed all of the relays, cleaned the connections and returned them confirming they are tight in the sockets. (But if it was a loose relay, I suspect that it would not start on the 2nd try??) It is now due for the 3000 mile service, but I wanted to get some input from this knowledgeable group just to be sure the dealer does not try to give me a snow job as a Christmas present.
Thanks in advance.
Thanks in advance.
