2013 RT headlight and foglight modification
wis2013rtltd
question.
Would like to upgrade the quality and quantity of light on our 13' RT Ltd. I have looked at forum sponsors etc. and I seem to be more confused now then when I started....
Can someone with a 13' whom has modified their lights chime in and the mods you have done and your source for parts please. Brighter is better and thats our goal.
Replaced the laps with HID modules from XID. 9005 for headlamps and H11 for the driving lamps. Get the Xtream digitial kits with the slimline ballast and the install is fairly easy. MUCH improved lighting and visibility. I went with the crystal white 5000k color that matches the white led fender and accent lights.
do you by chance
Have part numbers? Sounds like what I'm looking for...
I gave the info in the first post. Ordered the Xtream digital HID kits from XID (sponsor on this site) one kit 9005 and one kit H11. The headlight ballast is mounted in the nacelle behind the headlight using the supplied 3M mounting pad. The fog light ballast fits inside the fog light housing without modification. Its a snug fit so no mounting or bracket required, it just fits.
Thanks for the
input, I appreciate it.
