2012 RT Fog Light Install
This is a little off topic, but still fog light related. How do you aim the fog lights? I know how to do the headlights, but I can't find any adjustments for the fog lights on my RT.
I'm getting ready to install my elka shocks. The dealer should be getting them anyday now. I've read that the elkas raise the front of the RT a bit. If the spyder is higher in the front, I know I'll have to adjust the lights.
http://www.spyderlovers.com/forums/showthread.php?41290-Fog-lights&highlight=Sinkhole
Make sure the 12volt plug for the GPS does not have a little circuit board in it. If it does there will be a small drain on your battery even if the gps is not plugged in.
I used the OEM 12v plug for the frunk and a Garmin GPS--I'm assuming that everything will be OK?
