2010 RT trailer wiring
tbowman
Can the existing wiring on an RT be tapped into and ran thru an isolator circuit relays to tow a trailer other than the BRP trailer? Will this create computer problems for the VSS, ABS, etc.?
welcome
You won't have any trouble with the computer, it's doesn't know you're towing a trailer.
picture.php
I am towing two different non-BRP trailers. Both have separate turn signals and 6-pole plugs. I bought the BRP Trailer Tongue Harness P/N 710002029, and built my own adapter. If you have a trailer without separate turn signals, you will need an additional converter. You won't need an additional isolator if you have the BRP hitch and trailer plug. The isolator module is already built in to the harness.
Converter ?
I have wired my none BRP trailer using the wire diagram posted above. I used the BRP harness ... all works great .... BUT after about 15 miles the RT will go into limp mode and shut down, I stop and wait about 1 minute and it fires right up, it continues to do this so on this last trip to Ca. to Corbin I unhooked connector and ran with no trailer lites. My non BRP trailer set hight wise low enough that the Spyder lite can be easily seen from the rear. What did I miss in the wiring set up and you mentioned additional converter ( :dontknow: ) purpose and where would this be placed in the flow of the wiring?
Thanks ahead.
Thanks ahead.
I have had no such problems. Hard to diagnose your problem remotely. Do you have separate turn signals on your trailer? If not, that could be the source of your problem. You would need a 5-4 wire (3-2 wire) converter. Basically your circuits would be crossed at times. It could also be a short, too much lighting load...or even a non-related issue. When the Spyder goes into limp mode, you need to check the fault codes before you shut it down. If the problem remains, PM me and I'll send you my vitals so we can discuss it further, offline.
BRP trailer harness
I own a Fibro Concept Trailer that I used with my Goldwing before trading it for the RT, a much nicer looking trailer than the BRP one. I bought the BRP trailer harness and wired it to my trailer, all works perfect. Just need to get the trailer painted to match the RT, thanks for all of the info.
You know, if there was ever a niche to be filled, some smart vendor should manufacture an adapter to plug into the spyder and connect to a four wire trailer system. No need to read and interpret a diagram. Just plug and play baby!
I for one would purchase such an item!
