Results 1 to 19 of 19
    Aug 2007
    Springfield, MO
    Default Lamonster RTW Project- New Ram mount locations
    While I was in Daytona I got to see a few RT's with the chrome wind deflectors and they looked really sharp. I decided it was time for an upgrade and seeing I had ram mount balls on my deflectors I was a little reluctant to drill holes in the new chrome ones. As I started looking around I found another great place that works just as well for my cameras and I could even mount my cup holder or iPhone in the same place and it looks pretty good. I did have to drill a couple of holes in my dash and had to bend a 10mm wrench to hold the bolt but I'm really happy with this new setup.
    It was a real pain to get the bolt in from the backside but I was able to do it without taking anything apart other than popping off the speaker grill. This part of the dash is reinforced so it's a good solid mount.
    Here's the finish product
    This is with my Drift mounted. I have the ram balls on both sides so I can still run two cameras.
    This is with a long arm and a Ram cup holder.
    This is with the X-Grip for my iPhone
    This is the view with both ball mounts on each side
    Active Member Toys42's Avatar
    Jul 2009
    Argyle, TX
    Default New Ram mount location
    Nice job! Very clean and unobtrusive.
    Kevin
    2012 RT Limited (pearl white) + bling
    Very Active Member Arr MiHardies's Avatar
    Nov 2011
    Las Vegas, NV
    Where did you get the ram mounts?
    President - Spyder Ryder of America - Mojave Desert Chapter
    National Web Master - Spyder Ryder of America
    Dec 2011
    Bonita Springs, Florida
    Lamont, do you know them Ram part number for the ball or a good description. I assume it is just threaded with a nut ?
    Teddys favorite human CyncySpyder's Avatar
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Thumbs up Damnit Lamont, another GREAT Mod, Looks Great
    If you get time, & wouldn't mind, would you post a pic from the front of your RT with the ram-mounted cup holder on one side and your x-grip holding your Iphone on the other side? Im curious how much wind coverage they would have & can't picture it from the pics you have posted. Thanks so much & another Great Mod
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Alberts46 View Post
    This is the mount I used but I tapped it out for a 6mm bolt. If I was going to do it again I would run a bolt though the ball and put the nut on the dash side, it was way to hard to feed that bolt through the hole. The ball has a indent to hold the head of the bolt.
    http://www.gpscity.com/ram-mount-pla...-ball-rpr.html
    Quote Originally Posted by CyncySpyder View Post
    I'll try and shoot something for you today.
    Aug 2007
    Springfield, MO
    Nov 2011
    Las Vegas, NV
    What is that thing you have on your left handlebars next to your instrument cluster?
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Arr MiHardies View Post
    Remote for my cameras.
    Jun 2010
    Question Thank you so much for post'n the additionnal pics, I love this set-up, multi useful
    That looks great, thanks for share'n with the rest of us
    MOgang Member & Pyro-Man kevorama's Avatar
    Jan 2012
    Troy, MO.
    Lamont, I can't find the BRP handle bar Ram Mount that you mentioned in your video. The one that has the spacers and the four mounting bolts that go through into the handle bars. It doesn't show anywhere in their catalog on online.
    “Dream as if you'll live forever, live as if you'll die tomorrow.”
    James Dean
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    Looks great Lamont. Any handlebar clearance issues in full lock turn with the cup holder?
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    Aug 2007
    Springfield, MO
    Quote Originally Posted by kevorama View Post
    Mine came with the mount but I know the part number and cost has been posted here before. I did a quick search but couldn't find it.
    Quote Originally Posted by MarkLawson View Post
    Don't do full lock often enough to notice but I'm pretty sure it wouldn't be an issue.
    Jan 2012
    Troy, MO.
    I thought that I had seen it as well. The cost of $150 seems to stick in my mind. I did several searches with no luck. I'm going to call BRP and Ram monday.
    James Dean
    Registered Users bo9roadking's Avatar
    Apr 2012
    San Antonio, TX
    I'm not sure if it is the same one, but on page 55 of the 2012 Can Am Roadster catalog, there is a universal GPS support that is for an RS that might work. It has a 1" RAM mount ball on it with 4 bolts that mount on the handle bar. The part number is 219400331 and it costs $154.99.
    Aug 2007
    Springfield, MO
    http://www.rammount.com/CatalogResul...5/Default.aspx
    http://store.spyder.brp.com/product/...rt_and_Harness
    Jan 2012
    Troy, MO.
    Thanks buddy, I'll check on it. The RS and RT handle bars might vary on bolt locations. The price sounds right. BRP always tends to the high side.
    James Dean
    Aug 2007
    Springfield, MO
    The link I posted is for the RT
    Jan 2012
    Troy, MO.
    Many thanks.
    James Dean
