Zumo GPS wiring - what else can I use it for?
Amputeez
New owner of a 2015 RT Limited. I want to remove my GPS and was wondering what I can use the existing wire for? LEDs? USB? 12V? Thanks for the help!!
Well that all depends on whether or not you have the factory cradle still installed. The harness for the gps not only powered the gps unit, it also has audio to the factory radio (aux in) and a usb port. Most of those connectors can be found running along the right hand side of the gas tank.
You can use the same wires your Zumo's black & red (12v power) wires plug into for most assys like XM, CB, LEDs, USB adapter, or any other 12v items. Don't use those wires to directly power heated gear due to the current draw needed for heat. It can also be used to drive a relay for direct battery power to run a fuse box or air horn, etc.
The "GPS" plug is keyed power. You can use to power anything. If it is a lower draw item, such as a GPS, you can wire it directly. A higher draw item (lights, etc. can be powered with a relay using the "GPS" power as an ignition-on trigger.
