Your thoughts on using a Tackform Center mount?
Frustrated to find the hex bolt on the Rt is a different size then For the Tackform. Apparently I don’t have that size and will have to order it. Could someone be so kind as to tell me the bolt size on the RT?
I just realized that all the info that I posted was not what you were looking for, so I replaced it with this. I thought you were wanting a bolt, but you were looking for wrench size.
Carry on.
My bad. I thought I had added my bike in my profile. Nvm though I find the right hex to remove the OEM bolt. Thanks.
Dochands, It REALLY helps if you add your Spyder details in your Signature block, then when you post a question, everyone can see which Spyder you're referring to.
I have the TacForm mount mounted over my dash from a Spyderbar on my '13 and now my '18 RTL. I like the landscape view for mapping and don't have to look down at my handlebars.
Read my post above. I thought I had. Not sure why it’s not showing.
I just checked your profile, and you didn't have anything in the Signature Box itself, just in the 'Current Transportation' box - so I've added that info to your Signature Line, but it seems you don't have the 'Display Signature with Every Post' box checked somewhere, cos it still isn't showing.... :banghead:
Try clicking on 'Settings' up in the top right corner of the page & check/edit your Signature as necessary, then make sure you've checked any/all of the 'Show Signature' boxes on your profile; then back right out of the Forum before logging back in - that should reset everything & with any luck it'll show then. ;) If not, you could try clearing your cookies & history, but it'd probably help more if you drop me a PM so I can have a bit more of a look.... I will shortly be off the Forum for the next four hours or so, but will be back on after that... Good Luck! :cheers:
