What are you getting for MPG on a ST, RT etc...
Someone told me they have a 4 gal tank on a 2011 RT and can't go 110 miles.
MANY MANY VARIABLES....
Type of SPYD3R: RS or RT...
Number on board...
Total load being carried...
Terrain...
Elevation...
Weather...
Heavy Right Hand...
I checked my MPG during my ride from SC to UT last May... here in SC, we have 87 Octane... west of TX it's 88 octane... on my 4804 mile ride, my '09 RS averaged 33 mpg... my best was 37 mpg, worse was 31 mpg... I rode solo, and only carried luggage and gifts for family upon my return... none of which weighed more than 30 lbs, I weigh in @ 250 lbs... we rode on flat n straight, to curvy n twistees... hot, cold, 500 ft. elevation to 9500 ft. elevation... wet n dry...
and i have never heard of any SPYD3R with less than a 6.6 gal. gas tank... (i could b wrong however...)
:clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap: :agree: :2thumbs:Although the fuel tank capacity (except for the 2014 RT) is 6.6 gallons, only 6.0 is usable capacity. The low fuel light comes on with about 1.4 gallons left, more or less. If you get 30 mpg, you will see the fuel light at about 138 miles. If you get 25 mpg you should see it around 115 miles. Filling the tank is a little tricky. It needs to be filled by hand (not automatic) with the nozzle inserted just a little bit. Fill slowly and stop as soon as the nozzle kicks off. You can top it off a little to make sure, but stop for sure the second time it kicks off. Filling fast can fail to fill a small tank. Inserting the nozzle too far makes the pump kick off too quickly, resulting in an incomplete fill. Filling fast or trying to fill clear to the top can force gas into the emissions canister, causing gas fumes, a fire hazard, and wasting the gas which cannot then be used by the engine.
