spyderCodes
My F3, Pugsly is new enough that I haven't done any routine maintenance yet.
I have had the opportunity to do a few things like install Fog lights, LED headlamp bulbs, design & build a 5 circuit relay controlled wiring harness as well as stuff a heating element in the backrest.
Figuring out the reason the top black plastic cover over the lights wouldn't come off was interesting.
BRP attached 5 or 6 wiring clips from the bottom, making the stubborn cover appear to held down by magic.
With that mystery solved, putting the LED headlamps (TricLED) was fairly straightforward.
On my base F3 model the accessory service plug provided an excellent trigger signal for a relay that controls a separate 30 amp service for my heated backrest, 5Vdc bus for my Garmin and some LEDs and Denali driving lights.
Finding a trigger signal was always a bit of a chore on the early RT.
Here's a BRP mystery.
On the bottom of the backrest two zippers can be found.
The zippers look normal enough except the zipper trolley doesn't have a pull tab.
When I saw the zippers I thought all I would need do to place the heating element into the backrest would be to unzip the zippers.
WrongO.
The zippers appear to be a one time, one zip kind of thing.
Why Jean Luc decided to sew two zippers that cannot be unzipped into the backrest remains for me a mystery.
If anyone has an answer I'd like to know what it is.
I could have missed something as I know as much about zippers as I do most things.
And that's very little.
WrongO.
