Wiring question: Customer accessory harness
JimH
All:
Looking for a but of help here. I would like to install a Lamonster Bright Light on my 2017 F3 Limited. I watched the installation video a few times and it seems easy. Before buying I want to make sure my setup matches the setup on the video. When I remove the trunk the Customer Accessory harness I have does not look like the video. Mine is connected to another plug already. When it comes to wiring I am cautious, I don't want to do anything stupid and ruin the battery. Do I need to do something to the customer connection? Thanks in advance. I attached a photo to help describe what I am seeing.
Regards,
Jim
There should be a label on it which states Customer Accessory
Circuit
Just follow the lead down
It may be tucked under that connection shown in your photo
It has covered ends which allows you to add your own connector to it like leverlocks
Jim, on mine the accessory circuit came out out of the same taped wire harness that you have your finger on. follow that wire back and there should be another wire next to that one that has the customer accessory circuit tag on it like Eddie said. It is tucked up in behind and mine was hard to find. hope you find it.
Thanks guys - at break time I am going to go out and try to fish it out.
I appreciate the help!
Jim
Customer Accessory Circuit
Is the "Customer Accessory Circuit" Key'd or live all the time?
I am wanting to add the Garmin 396 and Dual USB to the switch panel by fog light and heated grip switches?
I have a 2019 Spyder RTL
Also is the a wiring diagram of the Spyder?
Ken
