I am looking to install a USB connector on my Trike using the Lamonster Garage USB setup that connects to their Spydercuff through a power supply. The instructions say that you should connect direct to the battery or an accessory connector. I took a look today and found two wires in a boot with solderless connectors. I measured 12.4 volts only when the trike is on. (I am not referring to the two-prong battery tender connector) Does anyone know what these connectors are? Everything I have read says that the RT does not have an accessory connection like the F3.
I attached a picture through a link
