I read this post because this is my first motorcycle and since it means so much to me I don’t want to have it mess up before I really get to do the miles on it that I want to do for the summer. I have a new storage shed coming in just for my baby I have on a jack now with two ramps for the front wheels so that when it rains noting hits the wheels I have the tender plus perminate cables put in for the charging and the outdoor cover till the shed gets here. My question I have is what is “top the tank” and “stabilize the fuel”. I saw in the beginning of the post to use gas seafoam mixture. What are these things and which is the best product to use I really love my bike and I wanted it to last for as long as I do. :dontknow:
There are probably as many combinations to this as motorcycle/car owners. My procedure is in another thread somewhere, but I'll try to summarize.
1.
Get the motorcycle to full operating temperature. Drives off any moisture in the oil, and makes fogging more effective (if done). A ride is best.
2.
Change the oil. (Optional)
3.
Fill (top off) the fuel tank. Helps keep condensation from forming in the tank. I normally ride to the gas station and get it hot that way, too.
4.
Add fuel stabilizer to the fuel. Stabile or Seafoam works well. Easiest to do this before the fill, but can be done after. Directions on container.
5.
Pump the tire pressure up to max sidewall ratings. As an alternative, jack it up. Keeps the tires round. I like your ramp idea for outdoor storage. Keeps the dirt from splashing up.
6.
Remove the spark plugs and spray fogging oil in the hot cylinders. (Optional) BRP's procedure suggests spraying through the intake, instead. Keeps the rust from siezing the pistons.
7.
Put the battery on a Battery Tender, Optimate, or Accumate charger. Don't use a conventional charger or cheap trickle charger, it can ruin the battery. This works with sealed batteries like the Spyder. Others, I remove and bring inside.
8.
Wax or polish everything with a good polish or car wax. (Optional) Helps keep moisture from affecting the paint and metal. Some say leave it on and wipe off in Spring, but I have had no luck with that.
9.
Cover. I would suggest adding a good, silver tarp over the outside cover if left outdoors. Please realize that moisture will collect under the cover no matter what you do, tarp or no tarp. The tarp just helps fight the heavier snow and rain, keeps the sun off, and helps the cover last longer.
Hopefully I didn't forget anything. Easier to do than remember exactly what I do. Multiply that by 23 motorcycles and some collector cars, and you see what I am up against. Takes several days. Just finished yesterday. Too bad we can't just ride all year here in the North.
-Scotty
