carbonation
As stated, a battery tender is a must. I've used several brands; almost all are good. I don't care for NOCO, they seem to fail early for me.
I'm using a Motopower from Amazon currently. I never liked having the frunk open for the tender lead, so I put a cigarette lighter plug in the glove box wired to the battery. The box closes over the tender leads easily.
Stabilizing fuel is important. I use Techron Marine from Amazon. It deals with the fuel, and it helps with moisture that the ethanol absorbs over the winter. Dose it before you fill the tank for the last time.
Clean, wash, wax. I spray WD40 in the muffler exit, and stuff a rag in it that was sprayed also.
