jcthorne
Well-known member
It looks a little tight but I think I can make something to work...
JT
Looking forward to see what you come up with.
JT
JT
This is my second dogbone.
It's starting to break.
I need to find out if it's covered by the BEST Warranty
I've been considering making a repair/reinforcement for the center bracket if there is enough interest in this.
JT
Check your windshield brackets often:
They have been known to fail occasionally. The consensus is if you run with your shield "full-down" most of the time, it will cause undue stress on the middle bracket, which raises and lowers the shield. Move the shield up slightly off the metal-stop to avoid the potential damage. Keep in mind you cannot replace just the bracket. The entire lift-mechanism has to be replaced to the tune of around $600.
http://www.spyderlovers.com/forums/showthread.php?41346-quot-Do-s-and-Do-Nots-quot-for-new-Spyder-owners
I'm at 17,000+ miles and still under extended warranty when I spotted the cracking. Talked with my mechanic and they have replaced a few assemblies at the ride's cost, not covered under warranty. When I mentioned others I knew of, he stated BRP does not think it is a problem so they aren't covering the fix. On the 2010s, he said you need the entire assembly and that is around $200; he said you can't get just the arm that breaks. I used JB Weld and so far seems to be holding fairly well but I'm watching these posts closely for a more permanent fix whether supplied by BRP or not. Rode with a group back in early June and we had to pull over one time when the leader on his 2012 RT had the arm break...a little disconcerting at 65 MPH according to him.
:clap::2excited:.......I have just finished making my first " re-placement " center arm bracket for the RT windshield ......I believe it is strong enough to tow my car. I just finished painting it so it hasn't been put back on my RT yet. I need to establish a procedure for re-mounting the arm and how it needs to be positioned so the windshield will operate within it's normal range.......More to follow.......Mikeguyver :thumbup::thumbup::thumbup:
:agree:.........However in the whole scheme of things a pic is not important ......The elements of the cure are .....I made two side plates ( of steel ) custom ground the ends of these to fit into/on the factory cast ends .......then I wrapped the entire " arm " with approx. 7 1/2 in. of 1/16 steel strap.......and then slowly welded the plates to the strap.....First one side , then I inserted the OEM arm , then put on the other plate and weld that....................I would BET MY LIFE that this will not break...............Prior to painting it , I actually put it in my vise and hit it a few times with a hammer ..............scuffed the metal slightly :yikes:..........but that was all it did ............It's going on my new RT to re-place the OEM piece. I'm not going to wait for that to break, which from the sounds of this thread there is high likely-hood ..............Mikeguyver :thumbup::lecturef_smilie: Michael...
If you don't figure out how to post pictures soon... :gaah:
:congrats: ...:agree:...:roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack:........PLUS YOU'VE MADE ME WET MY SELF WITH THAT JOKE :roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack:........................................pLEEEEEEEEEEEEEEEEEZE TAKE PICS :roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack:...........Mikeguyver :thumbup:I don't know what the bore dia. is on the arm... but it does not really matter... Looks to me like you could take a piece of pipe (the right size) and weld a plate in between and make a whole new arm... If no pipe is the right size...take a piece of solid rod and drill to right size. Looks easy to make....
