Shaft drive never "made it" on motorcycles. So why Can Am?
Are you kidding. Lots of motorcycles with Shaft Drive. BMW, Moto Guzzi,Triumph, Honda, Suzuki just to name a few.
FWIW, ‘Most touring’ is a little bit of a stretch , Harley still commands the largest touring segment and is 100% belt. BMW is ‘still’ plagued with weird shaft drive issues on a system they deployed fully 24 years ago. Shaft is definitely something with plusses but belt drive will take us years into the future with proven reliability also.
I've owned 10 bikes so far 4 belt, 4 shaft, 2 chain. My shaft drive were the best. Easy to do tire changes. No adjustments. And no rocks chewing up belts.
Since the Ryker was designed with a 900cc inline 3 cyl and CVT trans with the same wheel base as the current 1330 machines (67.3 inches), I would bet that it would all bolt right up to the 1330. The price reduction of $4K from 2018 to 2019 may be for inventory reduction - my money is on shaft drive for 2020.
Ehhh, no.
The 1330 with its 6 speed transmission is an integral design with a transverse output shaft and crankshaft. Shaft drive would require a complete redesign of not only the bike itself but the 1330 power plant as well. As long as the RT is the best selling Spyder they have, its not likely they will do a ground up new design of a touring bike. As the F3 shares the same drive train, same is true there.
I think you are much more likely to see a build out of the Ryker product line adding new models and more HP to the basic design. Think of the current Ryker as the F3S with T and L yet to come.....
The new Ryker 900cc is an inline 3 cylinder with CVT trans and shaft drive. I wonder if the shaft drive could be coming to the 1330 sometime in the future?
The #1 reason I'm "probably" not going to buy another Spyder is because of the belt vibration.
The idler has reduced belt vibration but only to bearable levels.
I tell people the F3 is NOT a smooth riding machine and always feel like I'm going much faster then my actual speed.
You have something else going on than belt vibration. Or you are particularly sensitive to engine vibration. The F3 is a VERY smooth riding bike on the highway. Granted with a belt tensioner added but it completely solves the belt vibration issue.
"felt vibration" is too argumentative or opinionated to discuss.
All I can say is that the vibration I do feel is comparable to my Suzuki Intruder 1400 (my worst vibrating bike) (My Harley "shook" but only while idling).
I have test ridden many other F3s and the "felt Vibration" was the same.
To me, the "felt vibration" is simply unacceptable so I would only consider another F3 if they cured this issue.
I agree with you. The belt tensioner makes it better but does not cure the problem. Mine only vibes above 70 mph. But comes and gos. Windy days make it worse because it creates a drag. Excel and decel at that speed will make it vibe to. Both my previous RT and current F3L will do it. I've had both brp and Doc's tensioners.
Hopefully the Spyder will not get shaft drive. While it is more reliable since there's no belt or chain to maintain and eventually replace, it is also more complicated. It is also inefficient, since the power flow has to change direction twice because of the gear sets needed. And, thanks to the clearance those gears require, there is more drive-line snatch engineered into shaft drive. A properly adjusted chain or belt will run smoother and have less slop. So, Can-Am, leave the belt on our beloved Spyder, please!
