Will I lose saved settings by doing a Battery Change?
floridarider
In changing the battery in a 2018 Spyder RT Limited will you lose any settings (radio stations, etc.) when you disconnect the old battery?
No, you're good, settings will be saved once you reinstall the battery. But getting the little bugger in and out of there is the challenge. Set the bottom in first and tip the top of the battery in last, reconnect your cables and you're all set.
