Will a Seat from a 2019 RT go on a 2011 RT?
Wrongway
My question is:::::
Will the 2019 RT seat fit my 2011 RT.
I’ve read it it appears that it will work but wanted to ask before buying it.
Greg
YES! :ohyea:
There may be some (relatively minor) variations in the moulding of the plastic pan underneath, but it'll fit & work well. ;) You won't be the first to have done it, either - others have been the Beta testers for you already! :thumbup:
My question is:::::
Greg
Yes it will fit. The only difference is the 2019 will have a built-in mount for the stock driver's backrest, should you choose to install one.
The 2011 seat requires you to cut into the seat to mount a backrest.
True 'dat! ;) But be aware, that 'built in' bit is just 'the hole', with a cover - there's an additional bracket that goes underneath the pan that you'll also need if you want to fit an OE Driver's Backrest. :thumbup:
