Will a Karavan Utility Trailer carry an F3 Spyder? Any input?
Frankab
I would like input on a Karavan Utility Trailer to tow an F3 Spyder. The dimensions: 5.5ft w x 9ft. L. Will this size work? I am mostly concerned about the width: 5.5ft. The length 9ft should be fine!
Thank you,
Frank
Spyder F3 is 104 inchs long, 59 inches wide. So on paper a 66 inch wide by 108 inch trailer can work, Lots of buts with the trailer tho. Make sure and measure the actual with and length. I have a 5.5 x 10 and that is tight maybe to tight for most people. a 5.5x9 leaves no room for error and may not work if you are looking to get the tongue weight at the hitch correct. Most would recommend 6x10 at minimum for an open trailer. or 7x10 minimum for enclosed trailer. Might look at the trailer area of the forum for other post on this issue https://www.spyderlovers.com/forums/spyder-trailers.185/
