Wife just called, oil symbol just came in and bike would not start.
Edsts
The wife sts has bout 2800 miles and has been running in great order . Today I get a call after she park and told me the oil symbol came on and the bike did not want to turn on , me thinking could it be low oil .
What type if oil should I get just in case it's low.
Sts may be due for oil, change almost hitting 3000 miles .
Gas this happen to any one .
When the engine is not running and the key is on the oil light will be and should be on because there is no oil pressure. This is normal and not a sign a problem. Need more details of "the bike did not want to turn on."
DO NOT ADD OIL.
DO NOT ADD OIL.
:agree:
Either it's in gear or someone bumped the red kill switch on the right handlebar..... Just guessing.
I agree, do not add oil. Like all motors the oil light will be on, when the ignition is on, and will only go off after it starts. Sounds more like a battery, charging issue? Also remember checking the oil when the motor is cold will not give an accurate level, and you could end up over filling!
Have to agree..!!
We need more information. Assuming all starting proceedures have been followed what is happening when the starter button is pushed..?? Did the oil light come on while running..?? If the oil light came on with all the others and stayed on this is normal. Assuming it's a 2013 from join date the battery should be good so it goes back to starting proceedure..key on..kill switch off..foot on brake..in neutral..(will start with brake depressed while in gear) hit the starter...now what happens...?? :lecturef_smilie:
My '13 will only start in neutral. Hitting brake does nothing when in gear.
Then you have a problem take it to the dealer. Foot on brake when you push the start button will shift it to neutral automatically.:thumbup: I always shift to neutral before shutdown so it is less strain on the clutch system.
