I have. 2010 rt never had a prob with canceling turn single just push the button in. All so most cars and truck when you Chang lanes they do self cancel. Seem to me just nick picking spyder and brp geeeee.
My BMW time or distance cancels I'm sure there is enough computer in there somewhere to handle thatThis is a problem that should be fixed. I do find myself looking down to see if I have turned off the signal after using it. Not good!
What I have done on highways at highway speeds in most cases when just going around someone is used my hands as a way of
letting drivers know. Not good I know but its safer than taking eyes off the road. LED is one thing that would help to see if there still
on but one shouldn't have to think about that as hard as we do. Hope something comes up that will fix this.
I've had the same problem and find myself often not using the turn signal to change lanes when the traffic's light. Just don't understand why it's such a problem to fix.
Had the same problem with our 2011 RT when first got it, but soon learned that if I push the button firmly and hold for just a second it works every time. Trying to just tap it like i did on my V-Star didnt work.
This is a seemingly minor Spyder RT defect that is usually considered just a picky complaint. My 2010 RT had the problem, but it is still the same on my new 2012 RT Ltd. The RT turn signals work just fine when you are turning corners and turn off as expected. but, when you are on an Interstate moving along at 70-75+ and make a lane change, no way will they turn off without precisely pushing the center button.
Without gloves, I can push that button straight and turn them off with one shot after a lane change, but... with gloves on I am lucky to get them off with less than 3 tries... in between the signal lights may go left--right--off-- etc before I can confirm they really did stop!
Now the real issue is that I can only confirm that they are off by looking down at the dash panel. This is where safety is the center issue. Moving your eyes down, off the hwy, at higher speeds is sure to have consequences. Riding on Interstate highways on a cycle is risky enough without having to look down (several times) at the dash to find out what signal you are sending to other drivers any time you change lanes. This whole thread was prompted by recently having a very close call due to another driver seeing the wrong signal.
I understand that the switch on the RS works much better... why is the RT so bad ?
This has all been documented many times, Why doesnt BRP fix it on the later model RTs ?
If any car signals worked like this, I believe there would be immediate action to resolve it. And, yes you can add aftermarket Leds to alert you about the signals but why are safety issues left to us?
I believe this matter is a serious Safety issue and hope that BRP is paying attention and will step up and fix it both in new models and for current RT owners.
Being the ole skool rider, I still give hand signals in the daylight hours and use the signals at night. So if it doesn't cancel, I know it. In todays distracted driving world, there is a lack of signal use anyways from most cagers, and is the reason I throw my arm out there for all to see. Could this be the reason it is called a self cancelling turn signal. ..I'm not putting everyone in the same catagory, but from what I saw at Spyderfest, we blow by most folks anyways, so the "optional"lane changing indicator would be irrelavent. And I would hope that we are looking into the mirror to see if the "optional"lane changing indicator is even an option. Besides most of the folks I saw in Cuba,Mo. had hands about 10 times bigger than the 1156 bulb camofluaged from the all mods.Which was pretty damn awesome if I might add..
