WHY Does The Ryker Get such POOR MPG???
Not much actual cross section against the wind! My Yamaha Majesty with LARGE custom mounted saddleboxes still got 50 MPG, and so did my Piaggio MP3 500 3 wheeler. Heck, my SLINGSHOT with 2,400cc engine and obviously MUCH heavier got better MPG than Ryker (and I used regular in Slingshot instead of recommended PREMIUM)!!!
You are correct, but it is not just about frontal cross section. How cleanly the object moves through an airmass is impactful too. For a motorcycle or three wheeler - with a rider perched on it - that is not a smooth service at the frontal, midsection or tail. So the surrounding airmass is very disrupted and flows are not smooth - and the rider and bike do not move through in a slippery fashion. Many jagged shapes and voids.
I just filled up again yesterday. Again all rides are 2 up in ECO mode. 116 miles and 3.2 gallons = 36.2 mpg. I am a conservative driver most of the time. With my wife as passenger I am very conservative.
My wife says she is comfortable on the back of the Ryker. Standard seat, 2-up rear spring set on 1. Together we weigh around 320 lbs.
Francis
Well said Ron. Was wondering if you can clear something up for me? Which type of trans does the Ryker have ? As on my 2011 RT 5 speed or 2014 RT 6 speed ? I hated keeping up with revs and tacs much less the fuel mileage on the 5 speed.
The one main factor for not very good mileage with the Ryker
and the Spyders is the Rotax engine.
It develops it max horse power at high rpm and that is where
it runs best and gets it best mileage. Lugging this engine
at low rpm and the mileage will suffer even more.
The Rotax and the auto trans in the Ryker were made for each other.
Even though its not the most fuel efficient engine it is a proven
bullet proof design for its small size that will take a beating.
It's a CVT, twist the throttle and go. No shifting.
Hey guys - Since CVT drives are new to a lot of bike riders, here's a fairly descriptive video on a CVT drive.
While this differs from the BRP clutch, it shows the same working principles. While these clutches are simple in operation, on motorcycles they have always been prone to problems. Unlike a gear box transmission, the CVT drive require maintenance on a mileage schedule.
Enjoy- Mike
https://www.youtube.com/watch?v=xHWqlfDZnmQ
I admit that I was surprised to find out BRP used the same final drive ratio on the 600 and 900 CC models. On all of my other shaft-drive bikes (BMW) the smaller motor models used a higher final drive ratio (higher RPM at a given speed) than the same model with the larger motors. The ROTAX engine produces a relatively flat torque curve and would operate more fuel efficiently at 1,500 RPM's lower at highway speed.
I have been riding snowmobiles with the same clutch(es) found on the Ryker for about 30 yrs. They have been trouble free, dare I say bullet proof under some very harsh weather and riding conditions. Only maintenance required is a belt change and quick cleaning. That can be done in 5 minutes on a sled. It will take a bit longer on a Ryker because of housing covering that area. This type of CVT drive system has been used since the 60's that I know of on all types of recreational vehicles. My experience started in the 80's with them. Sleds, quads, sxs, etc from a number of manufactures, not just BRP use this set-up in outside air temperatures from -40 to over 100 degrees on vehicles that travel through, water, mud, dirt, snow, ice. It's very rare users of these vehicles say, I blew my clutch. The entire clutch system has very few parts and even fewer moving parts. They are used in the powersports business specifically because they are known to be reliable, effective, easy to service and cheap. I think they have proven their reliability over the years.
I agree, the clutch system is nearly bulletproof.
They take much more abuse in an off-road machine than it will ever see in the Ryker.
My wife reports being comfortable on the rear seat. We have the passenger comfort seat with the high folding backrest.
My wife absolutely hates it with the same seat and backrest. I will admit the Ryker seems a little tippy riding 2 up
