daveinva
Note: I added the 4th question below, figure that helps out folks reading this thread understand and appreciate what's covered under warranty. :thumbup:
I saw in a different new rider thread the oft-mentioned Spyderlovers recommendation to purchase the extended warranty on the Spyder.
Like most of you, I did the same when I bought my Spyder three years ago; still got two more years to go on my extended warranty. Thankfully, I haven't had to use it.
That said, I'm always a skeptical sort, and it strikes me as surprising that I genuinely can't recall ANYONE using their BEST warranty in all the years I've been here at SL.
Actually, that's not true-- I do recall a few threads of people *failing* to get warranty coverage for their work. :shocked:
So, these are my questions:
1. If you used the BEST warranty, was it honored? If not, why was it denied?
2. Did you use the warranty during your stock warranty time, or during your extension?
3. If you used your warranty, either successfully *or* unsuccessfully, if you could do it over again, would you choose to buy the extension again?
ADDED QUESTION #4. If you used it, what did you use it for?
Thanks everyone!
Thanks everyone!
