Which works the best to reduce the heat??
I have the Spyderpops blocking plate and it helps a lot, but what is a "fan can"? If it helps with the engine heat, I need one. Thanks.
reduce heat
I put the missing air dam and air management system on my 09 rs and it really made a difference. Good luck.
Butch has the SpyderPops system on his "08 and I picked up ISCI's FanCan for my '12. They both work great...SpyderPops is black and basically cannot be seen and the FanCan is aluminum and can be seen in the vent (doesn't look bad at all in there). My 2 cents!
Beat the Heat
Ceramic Header wrap on the exhaust and Spyderpops block plate on my 2010 RT does the trick. This has been tested in the Texas heat.
Rick
Steve,
Do you still get a lot of heat between the glove box and the seat?
I do still have heat between glove box and seat, but no more or less than before. The real noticeable difference is when I am using my highway pegs. I'll be very thankful for the heat management on the road to Durango!
