Where to wire in a usb power outlet in 2016 rts
Leemorin
I want to add a usb outlet in my rts I am not sure where the best spot to wire it in is. Looking for your advise.
Thanks
lee morin
Are you familiar with how many people remove the Fuel and Temperature gauge on the RT?, if so your fuel and temp reading become Digital on your dash leaving you with two unused spots on your dash that have power. or are you just looking for a hot wire for your usb and a location to install it. let us know and we can help.
Cruzr Joe
I personally popped out my left speaker grill and put a hole in it the correct size for a dual USB. I grabbed power from the fuse panel at the frunk and wired it hot with ignition "ON". Very easy to do. Cruzr Joe's suggestion to utilize one of the gauge places sounds good too, but ya gotta figure out something to put in the second gauge spot.
I ordered a volt meter for one of the gauge holes and a 52mm gauge blank for the other with which i'll install a dual usb port.
Where did you hook to fuse block ? Which one (looking at front of Spyder ) left or right ?
