Great idea. I would assume that they could use the current ECM, since the engines are the same. Thoughts?
Regardless of where you get an engine, you
REALLY NEED to keep your existing
Engine Control, Transmission Control, and Dash/Console Modules unless you also change pretty much the rest of the bike!! Your Control Modules are tailored to the Spyder you have - it's not too hard to use BUDS to re-programme them to accept a different engine, probably not even necessary at all if you only change the short motor and stay with the same SE6 gearbox type; but it'll be a
SERIOUS PAIN if not completely impossible to make work if you happen to get & install an ECM, a TCM, or a dash/console that comes off a Spyder with a different rear sprocket - and given the year & model of your existing Spyder, that's a pretty high risk!! :shocked:
So sure, get a new/replacement engine/trans assembly if that's the way you want to go, but I'd suggest that you
DO NOT use any other ECM, TCM, or Dash/Console module without making sure that
EVERYTHING else between your bike & the donor bike is
identical! :lecturef_smilie:
Ps: And unless you want to open up yet another absolutely steaming can of worms, it'll be
a whole lot easier to do an engine swap if you get another SE6 - unless it's absolutely unavoidable, you
really don't want to try to graft in all the semi-auto clutch & shifter arrangements! :banghead:
