Where to by a RH grill
WhiteSpider
Greetings: This is my first day on the forum and my 2nd day of being a Spyder owner. Is there a place to buy a right side radiator grill cover? I've seen left, but not right. I'm assuming it matters? Thank you.
:congrats: Post pictures when you get some time.
RH Grille
Since BRP does not have any in inventory I would say your looking at changing them all out for stainless steel. Spyderpops or one of the other companies that sponsors or supports this forum would be my first choice.
Some one on the forum was saying they turned a LH grille into a RH grille the other day. Use the search function and do a little reading you will be amazed at the talents you will uncover here.
RH and LH grille
When I installed the easy access panel on the left side, the one to make it easy to do an oil change without pulling all tupperware apart, this bit of BRP kit came with a new LH grille. I then put the original grille without too much ado into the right hand opening, had to fit a small stud to stop if from moving but with a bit of lateral thinking it fitted just nice...problem resolved
Jos ( Down Under amongst the kangeroos)
