mecsw500
I don’t think anything that chocks in front of and behind the wheel is going to allow the Spyder enough ability to roll back over them in reverse if they are of any decent size.
With an e-track system you can loop from the floor, over the front tire, back down to the floor, through a loop and then extend rear wards before hooking to the floor again. Now you can ratchet the strap horizontally from behind the wheel making it easier to do in a confined space.
The rear you can use an e-track sideways to loop through the rear wheel and once again strap down horizontally.
It’s not too expensive stuff and you can overnight it from Amazon. I’ve used it in the past for small cars on trailers and it works great. Sometimes you can find it at harbor freight, Home Depot or lowes.
