When is BRP going to solve the faulty Throttle Bodies?
ulflyer
So many new Can Am's having the TB's replaced, some more than once, so obviously the replacement units are the same as what come with the machine to begin with.
Is it the TB themselves that are faulty, or is it a computer issue that cause the TB to go bad?
:banghead:
There has been a few changes to the TB that have pretty much solved the issues that were most common. The latest was a software fix. That's not to say a TB will never fail now but the won't fail for the same reasons as before.
Lamont,
It seems that all the attention has been directed to the 2011 & 12 model years. My 2010 RT is at the dealer now waiting for its second throttle body replacement. The first one went out in MT, and the second on the way to Cuba. Is there any reason to believe they have solved the problem with 2010's, or can I expect another failure in 4-5,000 miles? I'd appreciate any knowledge you can shed.
Thanks,
TB repair now 33.8mpg
I had work done on my 2011 RTS at Cowtown. Bike would not idle, spoke to Lamont and he directed me to the shop where BRP techs were helping out. Not sure what all they did but 2+ hours later the called my name and rolled the:f_spider: out for me. Did a short 55 mile ride that evening and then loaded it on the trailer for the trip home. This weekend the Minnesota chapter did a ride up north. For me it was about 250 miles round trip. I did not have any problems but kept looking at my gas gauge, it was hardly moving. Before the work was done my low fuel light would come on around 130 miles which meant another 30 miles before fillip. Generally got about 30mpg. On this ride I averaged 33.8 mpg. Kept to the speed limit and this was 1 up. What ever was done I am happy.
Lamont,
Thanks,
Yes, the bushings have been changed in the throttle plates.
I too have problems with the TB's. Mine quit in the garage so I was lucky and was not on the road. The dealer came and got it and it ran enough to get it loaded on the trailer. They had it for a week and found the TB was NG. They replace it and brought the bike back to my house which is 2 1/2 hours away and unloaded it. I took it down to the station to fill up and take a little trip to the coast for lunch. I drove 2 mile to pick up this young lady and when we got on the bike, LIMP MODE again and the bike shut down. Called the dealer and their driver was almost back at the shop. So, the next day they came and got again and guess up - started right up and climbed on the trailer without a faults showing. But they got to the shop and all three codes were there again. They reset it and drove it about 100' and she shutdown. A call was placed to BRP again and they said to replace the TB again as they are having issues with them. :(:banghead:
TB issues
My TB quit on my Smurfette, thankfully in my driveway and not in East Cupcake somewhere! I had been reading the posts regarding the issues with the RT's, and told my dealership about it. They are constantly amazed about the good information that's out here! Thank you again, my Spyder family:bowdown:
Great to know. NOW, how do I go about having BRP and my dealer replace mine? After a year long battle with the DPS unit on my 2010 RTS and finally having it replaced again last week, I'm not optimistic.
I am on my 2nd TB and they also replaced shims 2x. The bike is back in the shop again and I only have 1400 miles on it. We are afraid to take it on trips because not sure when its going to stop working.
It has been blamed on several things mainly the way I ride is what they are saying.
1. Fist time they said I was shifting at too low an RPM and need to shift between 3500 to 4000 RPM after a month in the shop.
2. 400 miles later they said that I was still running at too low an RPM and that caused it to go out again.
The service managers have been giving wrong info to me and it is not shifting at too low RPM it is running the bike on the streets at too low rpm. Big difference.
I had an 09 and never had this issue so I have a hard time with understanding why if I drive this one the same way that it causes this problem.
The RT is 230 lbs heavier that the RS and it is importaint to run at higher rpm's. On a SE the clutch is slipping under 3500 rpm's.
This is not a recall so they won't change it just because. If you have a TB failure then you'll get a new TB with the new bushings.
The throttle body on my 2010 was replaced under warranty and you could definitely feel a difference in moving the throttle butterflies between the two. The new one was much smoother than the old one.
Cotton
RPMs
A little over three weeks ago CanAm had a demo event out by me at a local dealer.
I went and test rode a RT, the CanAm guys leading the demo ride told me to not shift at all, until I got over 5,000 RPMs.
Just thought I would share.
Boyd
If running RPM's too low cause the TB to malfunction, why don't they recompute the computers on SE models so that they downshift when it gets "too low"?????
Also, why how does low RPM's affect the TB?
