What's best for Cleaning the Windshield? Anyone use Pledge?
I just wash it with the car wash stuff I use on the Spyder and dry it with a paper towel. When I have squashed bugs on it I'll wet a dryer sheet and then wash it right off...otherwise it'll scratch and leave a residue. I found any cheap dryer sheet when wet will dissolve the bugs off the paint, windshield, etc. and it works fine. Just be sure to wet it first and then wash it off right away. I used it on the stock windshield and the touring model I have on it now.
Got to try this tip!
Plexus is good, but I don't usually use it as a cleaner, but final coat. To clean it I use Stoners Invisible Glass spray and wipe clean with a microfiber cloth.
I use the Honda wipe down spray on everything, and it works great. You should be able to find it in the cleaning section of any dealer as well.
If you really want to get into detailing of your Spyder, you can check out this web site www.chopperdetailing.com for tips and products that work well.
taken from: www.calsci.com
specifically: http://www.calsci.com/motorcycleinfo/Fairing.html#Windshield
Cleaning your Windshield We make our own cleaning fluid. When you buy a windshield from us, we give you a small spray bottle of cleaning fluid and a micro-fiber cleaning towel. Here's our "secret" washing fluid recipe, the result of testing about 25 different formulas:
Makes 1 quart = 1 liter windshield washing fluid
  • 1/2 cup = 100ml ammonia (double this if you have a lot of bugs)
  • 2 cups = 400ml isopropyl (rubbing) alcohol
  • 1.5 tsp = 8ml car wash detergent (don't substitute dish soap or laundry detergent)
  • 2 cups = 500ml water
We recommend using only micro-fiber cleaning towels on your windshield.
Cleaning your WindshieldWe make our own cleaning fluid. When you buy a windshield from us, we give you a small spray bottle of cleaning fluid and a micro-fiber cleaning towel. Here's our "secret" washing fluid recipe, the result of testing about 25 different formulas:
Hmmmmm . . . Sounds a lot like Windex -- minus the color.
I use the CalSi formula and it is great.... even on other glass and mirrors.
And its cheap.
:agree: That's exactly what I do. Maybe I'm as smart as Forest...OK...I know I'm not! :D (I'll keep learning until I am!)
Edit: Yes, I only use microfiber clothes.
I only use Plexus or Honda spray. I Use it on the whole bike, also on my truck. Don't use paper towels, Paper towels should only be used to wipe off the dip stick.:D
I am also a fan of the Plexus/Microfiber combo....but I alos use the Rainx Foaming Cleaner - Then a coat of Rainx. This makes riding in the rain a breeze and this is also true for helmet visors! Beads of rain just boogie away in the breeze rather than getting in the way of vision!
Like it sez on the can,"Plexus is quite simply the most effective product you can buy for cleaning, protecting and polishing clear and colored plastics." Works for me on the body and sheild.
I use Next Dimension Spray Cleaner & Polish (previously known as Honda spray cleaner & polish) for most surfaces of the Spyder: windshield, panels, seat ...
I find that it works great for almost any surface except fabric.
I like Plexus but right now I'm out so I use plain water and a microfiber cloth. The best hint I know of when cleaning non-glass windscreens is to drape a wet towel over it and let it set for a few minutes before cleaning it. This moistens and softens the bug remains and, for the most part, they wipe off easily. I usually use my bare hand to initially loosen the worst of the bugs, then finish with the clean microfiber cloth. By the way, the towel trick works just as well on the rest of the bike.
Motels/hotels don't appreciate us using their towels to clean windscreens or bikes but I've found that if you ask at the office they usually are glad to let you use old, worn towels that I think work better anyway. And they are a lot happier to see you come back the next time.
Cotton
... When I have squashed bugs on it I'll wet a dryer sheet and then wash it right off...otherwise it'll scratch and leave a residue. I found any cheap dryer sheet when wet will dissolve the bugs off the paint, windshield, etc. and it works fine. Just be sure to wet it first and then wash it off right away. I used it on the stock windshield and the touring model I have on it now.
I found some time ago that glass cleaner makes squashed bugs real easy to remove. Spray on and leave for a minute, they soften and can be wiped away. Sometimes they need a second spray and soak, but they come off without rubbing.
Cheers;
Pogo.
My wife makes up a mixture for cleaning (mainly glass) that consists of ammonia, methylated spirits (a.k.a. metho - 95% ethanol) and water. It's the same mixture that was used to wash car windscreens when done manually (decades ago) then put in the washer bottle prior to ready made additives.
Metho is often carried on bikes (HDs and older Kwakas) that have carby icing issues as it actually mixes with water. Also use it to clean out your tank. Not sure what metho is called in North America (wood spirit?).
We have bottles everywhere in the house; medicine cabinet for cleaning cuts & sterilizing, cleaning cupboard, my shed, though it's not behind the bar. ;)
Whats the best products to use and the proper way to clean our windshields?
I use microfiber cloth and Novus 1,2,3 depending on scratches that need removed. #1 is for regular cleaning. Also I try to go up and down and not make swirls. Make sure keep any detailing polish from getting on the windshield as it will harm it.
