Either size should fit your 2017 RTL. Most have been using the 165/60-15 Q5.......:thumbup:
New front tires for my 2017 RTL Vredestein Q5 175/55-15 or 165/60-15 has a stock rear tire.
Thank you.
For fronts I went with the 175/55R-15. 8,000 + miles on them now and based on what I am seeing it's going to be a long time before they need to be replaced.
For rear I went with the 205/65R-15. 10,500 + miles on it now and I have the same prediction as the front.
So far I have had them in the heat, rain, and some snow and ice a short while back. I have nothing negative to say about them.
Thanks for posting this info ....especially the snow/ ice encounter ..... not many realize the Q-5 actually is good enough to get a " Winter " tire rating .... So even if you never get into snow/ice these tires will perform much better at cooler/cold temps. than most " all-season " tires ..... Mike :thumbup:
Mike, thank you for finding them and repeatedly posting about them. That's what caused me to get them to start with. Tried to get an actual tread depth today but couldn't find my depth gauge. Worst case I'll use a caliper and convert.
EdMat can you confirm you put the 175/55R front tires on a 2019 RT? I note that the fenders on that model are the same as for a 2019 F3 Ltd, which is what i have and want to ensure these tires would fit my F3 Ltd. We cannot access the 165/60's here in Canada without ordering from the US which becomes cost prohibitive. Did you have to shim the fenders at all or the tires work as is?
Thank you
Thank you
Just curious if you did a check comparing your speedo to GPS readings with that 205/65 rear tire. When I was replacing the OEM Kenda on our 2014 RT, I looked at several brands and sizes doing comparisons on reported sizes by the companies (knowing not all tires are created equal). I chose a Yokohama AVID Envigor in that size and then did the GPS testing with two different units over long straight, flat stretches here in the Tx Panhandle and found that size delivered almost perfect speedo vs. GPS results. Mine registers 75mph while GPS is showing 74.5mph. I'm very happy with that.. . . .
For rear I went with the 205/65R-15. 10,500 + miles on it now and I have the same prediction as the front. . . .
Mine is now within 1 MPH at 80. So much better than the 5 to 6 it was off.
